NI TestStand
Is there an example of a TestStand 3.0 UI, written in MFC.
I'd like an example of a TestStand 3.0 operator interface, written in MFC, that takes advantage of the new UI components. I found several example operator interfaces written for 2.0, but have not yet located a 3.0 UI.
(2,962 Views)
Hi Aaron,
In the TestStand 3.0 installation folder on your hard drive you can find examples of operator interface written in Visual C++ using MFC in the following locations:
"TestStand 3.0\OperatorInterfaces\NI\Full-Featured\C++ using MFC"
and
"TestStand 3.0\OperatorInterfaces\NI\Simple\C++ using MFC"
Both examples are using the new UI components.
Hope this helps,
Silvius
Silvius Iancu
(2,962 Views)
