NI TestStand
Is there any way to configure TestStand with Labview 6.1?
I´m trying to evaluate Test Stand Version 4.2.1 in order to update a Test System based on a register LabView 6.1 but I noticed that this version is not use on TestStand 4.2.1. Is there any way to configure TestStand in order to enable register Labview 6.1?. Thanks
(3,349 Views)
HI Elchampinion, as you mention the TestStand LabVIEW adapter only supports LabVIEW 7.1.1 and later. This doesn't allow you to call the VIs directly, the only option you could try is creating a DLL from you VI and call the DLL using the C adapter, that way you shouldn't  have the compatibility problem.
Still my recommendation in this case is update your LabVIEW License, so you can get all the new options that LabVIEW provides. You can contact the sales department in Mexico the phone  018000100793, for a quote on the upgrade, and you can download a free trial of LabVIEW from:
https://www.ni.com/en/support/downloads/software-products/download.labview.html
 Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,325 Views)
Duplicated post
use this one:
http://forums.ni.com/ni/board/message?board.id=330&thread.id=26761
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,313 Views)
