NI TestStand
Is there anyway to write sequence file without opening NI teststand 4.2 ?
Hi Friends,
        I would like to know is there any way to write a sequence file without using NI Teststand 4.2 ?
       For Example, I will write few steps in a textpad or notepad in a format that teststand understand and save as .seq file, then I want to open that file file using NI Teststand and execute.
Krishna
Message 1 of 16
(5,808 Views)
TestStand files are stored in binary format so I doubt that's possible.
What you would have to do is create your own code that read in a text file and then called in to the engine through the API to create the sequence.  It would be painful but doable.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 16
(5,802 Views)
Sorry,
You could also do them as XML files.  To see what one looks like go to Edit>>Sequence File Properties...  Then change the File Format to XML.  Save the file and see what it looks like. If you created your text file like that it woud work..
jigg
CTA, CLA
testeract.com
Message 3 of 16
(5,801 Views)
take a look at the Sequence Builder example in the TestStand/Examples folder
Regards
Ray Farmer
Message 4 of 16
(5,787 Views)
You can use the TestStand 3.0 INI file format to store your sequence.
You can use (carefully) the LabVIEW configuration file functions to modify the seq file in the TestStand 3.0 format (again, carefully!)
We have many stand-alone tools that parse our sequence files (make no changes) and we still use the INI format to this day with TestStand 4.1.1
Message 5 of 16
(5,767 Views)
HI  Phillip,
        It's sound gr8 that we can write sequence files in ini format.
       Could you please attached with an example ?
Krishna
Ak Aerotek Software Center pvt Ltd
Bangalore
Message 6 of 16
(5,739 Views)
If you are starting from scratch I'd recommend the xml file format over the ini format because it is more human readable.
-Doug
Message 7 of 16
(5,728 Views)
You can of course change your setting so that TestStand SeqEditor saves the SequenceFiles in INI format. Check out the TestStand Help
Regards
Ray Farmer
Message 8 of 16
(5,712 Views)
Hi Krishna,
I am interrested in your idea behind why creating without Editor.
I if this would be my task would do it by using the TS-API.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 9 of 16
(5,705 Views)
You could try the route of using the Sequence File Translator
http://zone.ni.com/reference/en-XX/help/370052H-01/TOC34.htm
Regards
Ray Farmer
Message 10 of 16
(5,702 Views)
