NI TestStand
Issue Using TS API to Set LV Objects to TS Variables
I am running LV 21.0.1f1 x64 and TestStand 21.0.0.49156 x64.
I would like to create an object in LabVIEW then use the TS API to write the object to an object reference variable in StationGlobals.
The attached code results in error 1; however, this seems to be the same operation as a code module LabVIEW action step with a class method where the class terminals are wired in from TestStand object reference variables.
Let me know if someone sees a workaround here.
Andy Corbato
DMC Inc.
CLD, CTA
Message 1 of 1
(1,087 Views)
