NI TestStand
It's possible to change a value situated in User List with the API of TestStand ?
Hi
I would like to change the value of a variable situated to User Manager. Under administrator, we have acces to FullName, I I would like to modify a value which I added to this level. I have administrator / test which is a number which I want to change there accedant under LabView.
I hope that it is clear
Thank you
Will W
(2,898 Views)
Will.
1. Obtain the desired user object using Engine.GetUser.
2. Convert the user object to a PropertyObject using User.AsPropertyObject.
3. Set the value of the desired number property using PropertyObject.SetValNumber.
Hope it helps.
Antonio Lie.
(2,885 Views)
