NI TestStand
Keithley 2700 example request
I am having trouble understanding the IVI driver for the Keithley 2700.
Using:    :\Program Files (x86)\IVI Foundation\IVI\Drivers\KE2700\Keithley.IVI.NET.KE2700.dll  If you have a better driver solution my ears are open.
My goal is to read VDC on 4 channels of a 7708 card. The driver uses the standard IVI DMM but adds some extensions to do multi channel and it's confusing me. Could someone provide an example?
I am also curious if the same sequence written for an Agilent 34972A would work on the Keithley 2700 if the Query Instrument is set to false to prevent the error of incorrect instrument detected.
(5,400 Views)
Hi PatSpring,
There are several examples found in the following location once you have opened LabVIEW: Help >> Find Examples
Here you can search for "DMM" and you will see several examples that will help get you started. What version of LabVIEW are you using? Keithley also has several LabVIEW examples on their website, but most are for LabVIEW versions 6 and 7.
Kevin S
(5,346 Views)
