NI TestStand
Known issues with regards to execution time on Teststand 2010 when upgrading LabVIEW 8.5.1 to LabView 2011 to create VI for test sequence?
Is there any known issues or KB for this situation? because when using 8.5.1, the execution takes 7 mins and when using LabVIEW 2011 the execution takes 3 times longer
(2,854 Views)
George,
Can you explain the 7 mins, is this the first VI that is created or editted. Is LabVIEW already running when invoking the create or edit?
Regards
Ray Farmer
(2,853 Views)
