NI TestStand
LV Operator Interface: Cleaning Data Report Space
Hi, I'm using Test Stand 3.1 and LabView 7.1, I have a LV Operator Interface and I'd like to reset (clean)  Data Report space between Sequences execution. I have tryed everything with no success.
Thank you,
Massimo Ponte
(3,596 Views)
When you say "between sequences execution", do you mean after each sub-sequence has executed and returned to the MainSequence.
Also, by Data Report space, you you mean the Report window of the Operator Interface.
regards
Ray Farmer
Regards
Ray Farmer
(3,592 Views)
I have a test sequence that generates a report, on the next execution I'd like to clean the windows that contain the data report.
Thank you.
(3,569 Views)
When you say "on the next execution", do you mean your test is being run with Test UUTs and after each UUT that is tested you want the report to be blank? Or are you referring to each time you run it with single pass, you would like the report window to be cleaned?  Also are you using the full featured operator interface or the simple one?  If you give us a little more detailed explanation of what you are looking for, we can try and help.
Pat P.
Software Engineer
(3,519 Views)
