NI TestStand
LV TestStand OI under 6.1 Generates runtime menu errors
TestStand-Enable Entire Menu.vi generates an error when I run the TestStand OI under LV 6.1, LV 6.0.1 is fine. The Menubar reference number gets lost on the way through the vi. If the submenu tags array is empty, as is the case when it is first run, the menubar reference number is lost(0) on the output of the for loop. I have confirmed this behavior with a small sample vi consisting of a control wired through a for loop to an indicator. The for loop is indexed by a control array wired to the loop border with indexing enabled. If the Control Array is uninitialized, the value is not passed under LV 6.2, but is under LV 6.0.1. My solution is to test for an empty array and if so, pass the menubar number through.
(2,909 Views)
There's an update you can get from here
http://digital.ni.com/softlib.nsf/websearch/311C9AFFC0B3D84A86256B6B0072F58A?OpenDocument&node=132070_US
and it will fix the problem.
Also spotted another update for 2.0.1
http://digital.ni.com/softlib.nsf/websearch/61BEF7B61824DFC086256B9900781C68?OpenDocument&node=132070_US
maybe of interest.
Regards
Ray Farmer
Regards
Ray Farmer
(2,909 Views)
