NI TestStand
LV runtime engine compliant with development environment?
Hi guys,
Can I use a LV RTE on a system who has already a development environment? Can I use this RTE in teststand while the development environment is on the same system?
(3,254 Views)
You have to reconfigure your LV adapter in TestStand. Please open Configure>>Adapters and select the LabVIEW adapter.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,252 Views)
But I can install the LV RTE on the same system?
(3,249 Views)
You should already have a LV RTE installed with the Development System. But if you haven't then you can still install this as well as your development system.
Regards
Ray Farmer
(3,247 Views)
