I need to run a TS sequence just before exiting my operator interface (a modified version of the full featured OI). I use InvokeNode to call it in my "Exit" case, with the CallFrontEndCallbackEx method. I wire the Execution output from the method to call Execution.WaitForEndEx, with a timeout of -1 (no timeout), and I expect for it not to come back before the callback completes. But it does come back before completion, apparently, and since the next thing I do is request a shutdown, I get a message 'Cannot exit while a sequence is running' and the application hangs. If I force a delay or simply remove the code that calls the callback, I don't get th
e same problem.
(In the attached code example, ignore the fact that we're getting the Execution.Id and not using it - we know that should be removed.)
