NI TestStand
LVRuntime 7.1.1 breaks TestStand
I get a -18004 error whenever I try to run vi's using the LvRuntime engine in TestStand, this occured after I applied the LabVIEW 7.1.1 patch, yes I did recompile everything. Is this a known issue or a new bug.
(3,007 Views)
Please check that the Adapters are set to the LabVIEW Run Time Engine 7.1.1. For this you would have to go to the TestStand Sequence Editor. Click on Configure>>Adapters... Select LabVIEW>>Configure... and set the RunTime Engine to 7.1.1. You would need to compile your VIs again.
Thank you
Nandini Subramaniam
Applications Engineering
(2,987 Views)
