NI TestStand
LabVIEW 2020 SP1 f1 crash TestStand sequence editor
Hi.
I have a VM running TestStand 2020 and LabVIEW 2020 SP1. This has been running fine since august 2021, but yesterday I updated to LabVIEW 2020 SP1 f1. After that I can no longer load anything LabVIEW related in in TestStand. All I have to do to make the sequence editor close without warning is to open it and insert an action step with the LabVIEW adapter selected. This will frees the UI for a few seconds and then the sequence editor window just closes.
I discovered that there also was patch for TestStand 2020, and installed that in the hope that it would fix the problem. But it did not help.
Has anyone else had this experience?
Best regards
Jens Christian Andersen.
CLA, CTA, CPI
Message 1 of 1
(1,096 Views)
