NI TestStand
LabVIEW 7.1 add flow control to TestStand
I am trying to write a LabVIEW vi that adds flow contol functions (FOR, FOR EACH . . .) to a TestStand main sequence, and create the needed Locals variables.
Respectfully,
Robert
Message 1 of 9
(5,147 Views)
Robert,
Can you be a bit more specific regarding any problems you are having with the task you undertaking?
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(5,142 Views)
My operators are using the "Debug" version of TestStand, so they can add steps to pre-existing sequences.  They asked me to write a custom step that opens a LabVIEW vi when they select/edit the custom "FOR EACH" step, so their entries will automatically insert/configure the "FOR EACH" step for them.  These changes/additions will be made when the sequence is not running.
Respectfully,
Robert
Message 3 of 9
(5,131 Views)
Hi Robert,
So are you trying have a LabVIEW action step that simply launches a VI, asks the user for a sequence file path, and then inserts a step into this sequence file?
If you are tyring to do something similiar, you may want to take a look at the Programmatically Inserting a Step Into a Test Sequence using LabVIEW example.
Hope this helps!
Best Regards,
Jonathan N.
Message 4 of 9
(5,112 Views)
Jonathan,
The vi you suggested does not support flow control (FOR, FOR EACH . . .).  NewStep==>stepTypeName==>StepType_???
Do you have any suggestions for flow control commands?
Respectfully,
Robert
Message 5 of 9
(5,109 Views)
Hi Robert,
That example VI does support flow control, it just doesn't show it. The NewStep method in the example VI only shows pre-defined constants being converted to a string to be evaluated. Some of the step types do not have pre-defined constants. Thus you need to refer to the Type Palette to see what the string parameter "stepTypeName" should be. For example, as shown in the attached image, you would use the string NI_Flow_ForEach to insert that ForEach flow control step. For the "adapterKeyNameVal" parameter, you would just send in an empty string.
You can see the string names associated for each step type by opening the Type Palette and seleting the "NI_FlowControl.ini" file from the Palette drop down menu.
Hope this helps!
Best Regards
Jonathan N.
Message 6 of 9
(5,101 Views)
Johnathon,
Where would I find a list of these NI flow step types?
Respectfully,
Robert
Message 7 of 9
(5,085 Views)
Hi Robert,
As I mentioned in the previous post, the list of the NI types are found under the the Type Palette in TestStand. Then choose the correct .ini file such as the NI_FlowControl.ini file that shows the names of the flow control types. All you have to do is look there.
Hope this helps!
Best Regards,
Jonathan
Jonathan N.
Message 8 of 9
(5,080 Views)
Thank you,
Robert
Message 9 of 9
(5,075 Views)
