NI TestStand
LabVIEW VI with Report Generation Toolkit elements in a TestStand sequence does not run with a LabVIEW 8.5 Run-Time Engine
Hi all,
I am using LabVIEW 8.5.1 and TestStand 4.1. I have done a TestStand sequence with a VI in it, which uses Report Generation Toolkit elements. On my machine I am using LabVIEW and TestStand with a Development System license. On the other machine I am using TestStand 4.1.1 with a Base Deployment license and I have chosen the LabVIEW 8.5 Run-Time Engine in the Adapter Configuration. Everything is running well except of this VI with Report Generation Toolkit elements. The error message is showing that the VI is not executable. It works well only after I have installed LabVIEW with an Evaluation license and chosen LabVIEW 8.5 Development System in the Adapter Configuration.
I have found other posts and a document in the KnowledgeBase with a similar problem: http://digital.ni.com/public.nsf/allkb/8A0E6274D9BD7B1986256F62006AD402?OpenDocument But I am not using EXE files in my sequence, so I don't know how to solve mine. Anybody has an idea?
Update:
I have also found this document in the KnowledgeBase: http://digital.ni.com/public.nsf/allkb/9E00E7EFE0635E678625734600779EFE But after copying all files from ..\addons\_office\ to C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.1\Components\RuntimeServers\LabVIEW\data\ nothing changed. I still get the same error. Do I have to uninstall the LabVIEW 8.5?
Are there any other things to do?
Uninstallation of LabVIEW didn't help, now the driver VIs are missing too. I hope my description is precise enough! It is very simply to try this out: Just build a VI with Report Generation Toolkit functions in it. Then place it in a TestStand sequence, choose LabVIEW Run-Time as Adapter in the "Configure > Adapters..." Menu. And do a "Single Pass". I am trying since a couple of days and running out of ideas...
I have also posted this thread in the LabVIEW board: http://forums.ni.com/t5/LabVIEW/LabVIEW-VI-with-Report-Generation-Toolkit-elements-in-a/td-p/1207747
Message 1 of 1
(4,130 Views)
