NI TestStand
LabVIEW VIs called from teststand have no taskbar button on Windows
Hello, I cannot figure out how to make LabVIEW popups behave well in TestStand. My sequence has popups with graphs, in some cases more than one at a moment. The goal is to either have them always on top of TestStand or to have a taskbar button as a separate process so I can return to popup once hidden. Currently even when I experimented with different VI appearances (modal, floating, standard), it hides behind the teststand window and I have to manually move the Teststand window. My setup:
LabVIEW Runtime is used in LabVIEW adapter.
The VIs I call are members of Packed Project Library.
I actually do the test in LabVIEW app which behaves as a GUI to Teststand sequence, so I invoke the TestStand from the GUI via TestStand API, but this behavior is the same in LV and TS.
Has anyone dug into that?
(142 Views)
Modify your VI to call TestStand - Start Modal Dialog
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/lvteststand/teststand-start-modal-...
George Zou
(122 Views)
