NI TestStand
LabVIEW class calling makes NI TestStand really slow
Hi All,
I am using NI TestStand 2014 SP1 with LabVIEW 2014. When I call LabVIEW VIs within TestStand, it just works fine and loads selected LabVIEW VIs pretty quick. But the same thing when I try with LabVIEW classes, It takes few minutes (5-10 minutes) to load after clicking on any LV class module step. I understand that loading all VIs within a class may take a while but it makes really difficult to create/modify any step.
Am I missing anything which could allow my classes to load faster in TestStand? I have verified my search directories and module adapter which looks fine to me.
Please suggest if anyone has faced similar situation.
Thank you.
(2,140 Views)
Are you passing the LabVIEW project as well? If you are remove this from the step specification.
Regards
Ray Farmer
(2,121 Views)
Hi Ray,
Yes, I was passing project to step settings. It looks little bit faster after removing project, but still it is slow. Now it take around a minute or two to load the step. Do you have any other suggestions that may still speed up loading of steps?
Thank you.
(2,112 Views)
