NI TestStand
LabVIEW developer adapter won't load
Hi there,
We are using TS4.1/LV8.6f1 and we are running in to this issue. Basically when a LabVIEW module is selected the LabVIEW adapter ocasssionally won't load the prototype. LabVIEW is actually launched and we are able to open and modify VI's.
Anyone seen this problem before? Are there any conditions that would cause this to happen?
Thanks!
<<- N ->>
(3,229 Views)
I was wondering if this occurs in a specific sequence file or when the step references a specific VI, or is it more general.  Also, have you tried running a repair of TestStand?
Hassan Atassi
Director, ni.com
(3,191 Views)
Hi Hassan,
We ran a repair and that didn't help, the problem ocurrs randomly with different VIs...
<<- N ->>
(3,181 Views)
I was wondering if you are using the LabVIEW development adapter or the run-time engine.  It might be an interesting test to switch this and see if you get the same behavior.  Also, it might not be a bad idea to reapair LabVIEW as well.
Hassan Atassi
Director, ni.com
(3,161 Views)
