NI TestStand
LabVIEW.ini location for TestStand with LabVIEW runtime engine
I am creating a test with TestStand using LabVIEW.  I added background and foreground blinking colors to the LabVIEW.ini file.  When I switched to the LabVIEW runtime engine, it returned these colors to default.  If I were making an executable in LabVIEW, I would modify the application ini file with these values.  When TestStand is running with the LabVIEW runtime engine, where do these values go?  I was thinking maybe the TestExec.ini file, but can't figure out where I would put them or if the syntax is the same.
(4,486 Views)
Accepted by topic author brindlaj13
It depends what user interface you're using. If it's a LabVIEW built user interface, you can add it to TestExec.ini similar to LabVIEW.ini. If you're not using a LabVIEW built UI, you'll need to add an LVRT section:
[LVRT]
blinkFG= [color in HEX]
blinkBG= [color in HEX]
 Using LabVIEW INI Tokens with VIs Called from TestStand
Make sure you restart the application after you make changes to the ini file.
-Trent
https://www.linkedin.com/in/trentweaver
(4,461 Views)
Perfect! Thanks!
(4,458 Views)
