NI TestStand
LabVIEW module use DLL
In a teststand sequence file, it uses LabVIEW modules that call .NET DLL.  The DLL cannot be linked to the program.  If I were using LabVIEW only, I know that I can insert the DLL into a LabVIEW project and the VI in the project will know where the DLL are.  However, I am not sure about teststand.  Can someone help?  Thanks!
Kudos and Accepted as Solution are welcome!
(4,448 Views)
Are you asking because you want to deploy the system? If yes, you should create a workspace and add the .NET DLL to your project as additional file. You can use the Deployment Utility to include the DLL in a MSI (Microsoft Installer).
If you are NOT asking in the context of a deployment, please elaborate your question....
Norbert
Norbert
Expert: Geometry
(4,415 Views)
Problem resolved.  The contractor forgot about the configuration for .NET 4 DLL.
(4,379 Views)
