NI TestStand
LabVIEW runtime error in TestStand
Yes i have
Message 21 of 22
(1,090 Views)
Hi all,
So, this is odd. Why would that DLL be stored under TestStand/Bin/<vi.lib>?
missingRefees: [ { refType: "DNVA"; refIdent: { name: "itextsharp:4.1.6.0:neutral:8354ae6d2174ddca"; path: "C:\Program Files\National Instruments\TestStand 2020\Bin\vi.lib\Exaprom PDF\DLL\itextsharp.dll";}; }		];
@DavideBrus, does that path exist on your deployment system?
Also, could you add the following token to your LabVIEW.ini file, restart LabVIEW, and re-build the PPL? It will generate a detailed build log and store it in the same location as your project.
NI_AppBuilder_Logging=True
Looking forward to hearing from you.
Felipe Flores
Technical Support Engineer
Message 22 of 22
(1,047 Views)
