NI TestStand
LabVIEWAnalogWaveform type passed as Variant generates Error
I am passing a "LabVIEWAnalogWaveform" from Teststand  to Labview  as a Variant type but it gives error.
The Variant is passed to  generate a TDMS  channel data.
I also pass numbers ,strings, num arrays, sting arrays to the same variant but they work fine except for  analogwaveform type.
has any one  had similar  experience while dealing with waveforms
I am adding a png file which shows the same.
(4,314 Views)
Hey,
Can you share a simplified example that illustrates the issue?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,250 Views)
