NI TestStand
LabVIFile not found, when try to start sequence, but step settings are fine
I build some LabVIEW packed libraries and want to use them in a TestStand sequence.
Configuring the step settings works fine and no error is reported:
When I try to run a sequence with that step in it, TestStand show me this error message: (LabVIEW Hex 0x7 File not found)
When I go the step and look at the Step settings again, Everything is still fine.
When I click "Browse for VI" and choose the same VI again, and try to run the sequce again, it works.
So the file is not corrupt and the path is correct.
After safing, closing and opening TestStand the error will ocour again.
Can someone explain this strange behaviour?
(2,152 Views)
Hello RobinLueft,
Which LabView version do you use?
Also, you can try to unload all modules and config again their path, then save it.
Best Regards,
Edgar.
(2,094 Views)
Hello EdgarU,
I am using LabVIEW version 20 SP1.
Unloading all modules, config the path again and savinging has no effect (as I described in my original Message).
It works for the moment, unitl TestStand is getting closed.
After closing TestStand and restart and reload sequence the error will ocour again.
Best Regards,
RobinLueft
(2,085 Views)
Hello Robin,
You can try the Update VI tool :
Make your VI folder writeable.
Open your test sequence.
Go to Tools - > Update VI Calls.
Do check if this resolves the issue.
Ravi
(2,065 Views)
Hello Robin,
For this, first, you will need to change your adapter to the LabView Development system, then go to the Update VI call.
There, you will need to change these two points: Process Express VI Calls and Process Standard VI Calls, and after choosing the "Update Calls" button.
Best Regards,
Edgar.
(2,056 Views)
What version of TS are you using and/or can you post an example PPL and TS sequence file that shows the issue?
Thank you
Anand Jain
NI
(2,049 Views)
