NI TestStand
LabView Error
Hello all,
I'm starting to do some Test Stand sequences, and I'm having a Fatal Error that is always forcing me to close the program. This error always happens in the first run and I just can avoid it by deactivate and activate one option in the adapters configurations tab.
The error that I'm having is the next one ->  "labviewv.lib was unable to locate a suitable location to resolve "MGApp". This may happen when too many instances of labview have been loaded into the same process."
Can someone help me to correct this error?
(3,238 Views)
did you ever solve this issue.
(2,639 Views)
Did you ever solve this issue? I am receiving the same error.
I have tried uninstalling and reinstalling Labview Runtime. Task manager shows only one instance of the software I am using so I am unsure what the issue is.
(2,388 Views)
Yes, it was not a LabView issue but a software issue.
(2,384 Views)
Sorry, I didn't understand if you were able to correct the error and if so, how did you do it?
(2,118 Views)
The software supplied to me that uses LabView was outdated. Later version of software solved the issue
(2,107 Views)
donde puedo escontrar esta nueva version del software?, que por ahora encuentro nada mas la antigua, muchas gracias
(2,099 Views)
