Hi meg57,
If you manually type the string value for that parameter, you will have
to include escape characters, entering double backslashes for every
single backslash. However, if the string is passed as a variable, the
escaping is done automatically, so in that case you wouldn't need to
include the double backslashes. Since you are entering the string
directly into the "Value" field of this module's parameter, you will
need to include the escape characters for this path to be interpreted
correctly.
Marty H.
