NI TestStand
LabView leaks memory when used with TestStand to log results to a database over 3 days eventually crashing the PC
We are attempting to setup an endurance test rig, that will eventually run for over 70days non-stop, using TestStand 3.0 and LabView 7.1 and after only 3 days we are already seeing LabView soaking up over 300 of MB of system resources to the point where it crashes the PC.
The PC is a 3.4GHz Dell with 256MB RAM and running Windows XP with no other software running besides TestStand and LabView (ie.. plenty of resources/power!).
The problem originally arose when we had 'on-the-fly' html Report Generation turned on in TestStand whereby after running an endurance test for over 16hrs the PC was found to be using over 300MB of memory and then the test ground to a halt and eventually the PC crashed.
Myself and Andy Long (Cyth Systems)asumed that this was related to having a large and rapidly growing html file open for the 'on-the-fly' html Report Generation (confirmed when we tried to open the resulting 30MB html file on another unrelated PC that also ground to a halt using 100's of MB to open the file).
We thought we had solved this problem when Andy Long set us up with Database logging of results and turned off the html report generation, and for a while everything seemed well but now we find that after running this endurance test for 3 days we have the same large memory usage and the PC ultimately runs out of memory and crashes.
It looks as though the changover from live html report generation to database logging of results has bought us a little extra time but the original problem is still there. It may be that the problem is infact unrelated to the method of logging the results (red herring?).
This endurance rig needs to run for over 70 days for some tests so the fact that the PC runs out of resources after only a few days is a major concern and a tricky problem for us to pinpoint.
The additional hardware is;
- NI PCI GPIB card
- NI PCI CAN 2-port card
- USB to 8 port serial adaptor
Various error messages are generated all as byproducts of the rapidly diminishing memory available and the PC grinding to a halt. The main fault being the windows 'Virtual Memory Low' message. Other faults include serial com port failures and GPIB comms failures most definately due to hardware/software time-outs occuring as the LabView software starts to run more and more slowly.
Any help you can offer is much appreciated.
David
Message 1 of 15
(4,302 Views)
Hi David,
A couple of questions;
1 Are you using the SeqEditor to execute your sequence(s)?
2 Where is the loop, in the MainSequence or in the ProcessModel?
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 15
(4,300 Views)
Hi David,
One point, although you have switch off the on-the-fly logging, you are still storing results so after you have logged your results in your database, you will need to empty the ResultList array. Otherwise this is going to grow each iterations.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 15
(4,300 Views)
1. No, I'm using a LabView .vi to start a TestStand Operator Interface and I run the sequences from there.
2. The loop is in the MainSequence, the ProcessModel being unchanged.
Regards
David
Message 4 of 15
(4,072 Views)
That would explain why we only saw a small improvement as we had only reduced the amount of data logged.
Is there an easy way of emptying the ResultList array?
David
Message 5 of 15
(4,300 Views)
Hi David,
Using an expression, use
RemoveElements(Locals.ResultList, 0, GetNumElements(Locals.ResultList)).
Another thing, do you have tracing on. The Labview status window is going to stack those results every iteration, so you will want to switch off tracing to minimize storing all that text within the OI. That doesn't get cleared until you start a new execution.
If that's the problem, you will have to modify the operator interface.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 15
(4,299 Views)
David -
To help figure out where the memory is being used up you might want to do the following tests. When doing these tests, use the OS Task Manager and look at the values for the LabVIEW process for columns Memory Usage, Threads, GDI and User Objects, and Handles to see if they climb over time. You will have to add some of these columns to the Task Manager because some are off by default.
1) Turn report generation off, and database logging off, and turn off result collection in the Station Options. Run your UUT test to see whether the tests/sequences and the OI themselves are using up memory.
2) Add back on the fly database logging, but make sure that the Model Option to conserve memory is enabled. This instructs the on-the-fl
y process mdoel callbacks to discard results after being processed because they are not needed later when the UUT completes it long testing run.
What database are you using?
Also, the OI does not hold onto any results, it should only display the state of the executing sequence at a single instance of time.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
Message 7 of 15
(4,071 Views)
David -
This is independent of the database logging feature, but there are some known problems with Microsoft's Internet Explorer control (used by OIs and the sequence editor) where it incorrectly holds onto memory. I know that TestStand 3.1 has made some changes in how it uses the control to limit the controls memory increases, but TestStand 3.0 did not workaround these problems as well.
Scott Richardson
Message 8 of 15
(4,071 Views)
Hi Ray,
Thanks for the help, unfortunately I'm seeing a type mismatch error when I try to run with this expression (see attached screen dump). It looks like it's expecting a string type where the '0' is in the expression. I'll try changing the '0' for a null string, hopefully that should do it.
I don't have any other LabView windows open, only the operator interface so I'm not specifically tracing the operation. Is there also a global tracing option that I need to turn off, I didn't see anything in the options?
David.
Message 9 of 15
(4,299 Views)
Hi Scott,
Thanks for the advice, I'll give this a try.
I did already do a quick check with Task Manager though and if I remember it was the LabView process that was using 300+ MB of system resources. I'll try this again and take a closer look.
I'm not using any additional database software on the rig though, I'm just running LabView under TestStand to generate the standard built-in TestStand results database. I then copy the database to another machine to analyse it later using a query setup in Excel.
I'm also looking at adding some database querying into the OI so that we can see some real time results for a few key steps. Do you think that this is something that is likely to use up excessive amounts of system memory (considering
that the database is already open in memory as we are saving the results to it)?
David
Message 10 of 15
(4,071 Views)
