NI TestStand
Label TS array elements from LV
How can I change the Label of a TS array element from my LabVIEW code??? Se picture added.
It is done when you insert at ”Multiple Numeric Limit Test” step in a test sequence and select “Edit Limits…” you get the “Edit Multiple Numeric Limit Test” dialog box. When this is closed with OK the Names of the Measurement Set is applied to the elements in Step.Result.Measurement. How can I do this from LabVIEW???
I am looking forward to hear from you.
Best Regards,
Morten Pedersen
CIM Industrial Systems A/S
(3,151 Views)
You can access the name of an object by using ActiveX to get to the step's Property Object. Once there, you can use a property node for the name and change it to write.
Let me know if you need more information about this.
Regards
Anders M.
National Instruments DK
(3,133 Views)
