NI TestStand
Labview RT Engine in Teststand
Have Testsand 4.0/Labview8.5, Windows XP.  Created seq.s and vi.s on my Developemnt machine.  In TS went to Adapters>configure and selected configure LV 8.5 run time eng.  Now anytime I try and run my seqs on the dev machine I get a Labview error ....
"error loading step "name of my vi" of seq main in file "name of my seq file".
Labview: the vi is not exe.  Mostly the vi is broken or one of its subvis cannot be located.  Open the vi in LV using File>>open and verify that it is runable.
Error code:-18002, labview reported and error. see :V: message for details.
Source:TSAPI"
I mass complied the directory where all my vis are.  If I go back to configure>> developemntl labview ...the seq runs file.
Basically all I want to do is run the LV rt engine and the TS developement environment on my developement machine.
(3,573 Views)
(3,538 Views)
Thanks Muks.  I searched on the error code.  Nothing like this came up.  I spoke to an App at National.  They suggested recompling my vi folder, which I did.  There was an old version of a driver in there that they think may have caused the problem.  Now I have to update the old driver and try again.  For the most part none of those possible solutions in your link applied to me.  Thanks anyway.
(3,533 Views)
Have you tried to make an application distribution? link:http://digital.ni.com/public.nsf/allkb/F3DC40A6E3F3B25B862570AD005D1D3D?OpenDocument
from the link
"An application distribution is like a source distribution that can be executed in a run-time engine environment. That means it includes all necessary VIs from vi.lib, which come with LabVIEW development versions but not the run-time engine."
Jim
(3,516 Views)
