NI TestStand
Labview comes to foreground during testing
i have a Problem with lost Focus in Teststand 2016 when calling a Labviewprogramm. I find a Switch (see pic) but this is not solve the problem. Is there any other place in Teststand or Labview to switch off the behavior that Labview is coming to foreground during test is running?Substep_Run.png
(2,680 Views)
Check with LabVIEW VI Properties
Uncheck show Front panel when Called.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,670 Views)
do you mean this Checkbox?
(2,658 Views)
