NI TestStand
Last Sequence File loads automatically
How do I set up TestStand 2012 so that the sequence file that was loaded last loads automatically the next time TestStand launches?
(5,726 Views)
are you talking about the sequence editor or the user interface?
In the user interface it automatically loads all the sequence files that were loaded when it finished.  Do you just want the last loaded?
There is not a way to do this directly in the Sequence Editor.  You can create a shortcute that launches TestStand with parameters.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,721 Views)
I just want the last sequence file loaded in the user interface.
(5,702 Views)
In the custom user interface, you can select between three options:
- ReloadFile_None
- ReloadFile_Selected
- ReloadFile_All (default)
This is the configuration of the Application Manager.
When using the NI SequenceEditor, it uses "None" option internally and you cannot change that. But the SeqEdit provides a "Most Recently Used" list which grants you fast access to the last files you used (i think up to the last 10).
Norbert
Norbert
Expert: Geometry
(5,700 Views)
Sorry - not familiar with Application Manager.  Can you provide more detail?  Thanks.
(5,670 Views)
Accepted by topic author VI_Joe
UI best practices: http://www.ni.com/white-paper/7560/en/
UI Controls: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CDsQFjAD&url=http%3A%2F%2Fwww.ni...
Hope this helps,
jigg
CTA, CLA
testeract.com
(5,662 Views)
