NI TestStand
Launch database viewer with command line
How is it possible yo launch databaseView.exe with command line in order to programmatically open and view a MDB file?
Thanks in advance,
Emmanuel
(4,538 Views)
Hello Emmanuel,
Sorry but what your trying to do seems to be impossible.
Alexandre M. | Certified LabVIEW Developer
Embedded and Control Systems Engineer (NI France)
(4,495 Views)
Hi Alex,
perhaps it's impossible, but how do you explain that we can launch the "Database Viewer" with "Connection String Expression" from the TestStand "Database Options" Dialog Box / "Data Link" Tab / "View Data" Button ?
Thanks for you help,
Emmanuel
(4,487 Views)
Emmanuel -
The DatabaseViewer application exposes an ActiveX server with the following interfaces:
Application with method Activate and property Visible.
DataLinkView with methods Show, refresh and NewSQLWindow, and property ConnectionString.
Scott Richardson
https://testeract.com
(4,455 Views)
HI Scott,
Thank you for your answer, that's what I need.
I just take time to localize the Active-X Class "zNI TestStand Database Viewer Version 1.1" (why "zNI ..." ?).
Just one remark : what is the interest of "DataLinkView methods NewSQLWindow" if we cant' call unexisting method "Execute SQL Commands " ?
Emmanuel
(4,381 Views)
Hi Emmanuel,
There is also a command line interface to Database Viewer.
Please refer to this help topic in TestStand help for more information:
Environment Reference->Database Viewer Application->Command Line Arguments.
Specifically for your use case, you could use "DatabaseViewer.exe -connectionfile <filepath>"
Hope this helps.
Tinu
(3,172 Views)
