NI TestStand
Launching a VI in parallel with a test
Hi all,
for a test on TestStand (v2017) I would need to launch a VI that acts as a logger, logging the broadcast messages of the modules I launch, so as to ‘intercept’ all status updates and have a way of checking what is actually being done by the VIs being called via TestStand.
I have created the VI that acts as a logger and, if launched from the project, it works without any problems, but if I launch it from TestStand with the ‘Run VI Asynchronously’ step, it remains empty, as if it did not receive any broadcasts.
The adapter is LabVIEW Runtime Engine and in the step settings I have selected ‘Use Context of Calling Thread’, how can I solve this?
Thank you
(443 Views)
do you specify a LabVIEW project when launching the VI?
https://www.ni.com/en/support/documentation/supplemental/13/how-teststand-interacts-with-labview-app...
(407 Views)
