NI TestStand
Limit List From Sequence File
In my sequence file I have approximately  2500 lines.  I have over 100 limits scattered about the sequence file.  Is there a script that can assemble and list the limits in an organized format available?  I am using TestStand 3.0.
Tony
(3,137 Views)
HI,
You could use the Import/Export Tool to output the limits to a file.
Not sure if with TS3.0 whether there is a <All Sequences> option, if not you will have to select each Sequence and perform the export of the limits and append the result to the file.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,133 Views)
