NI TestStand
Linked List
Is it possible to create a custom datatype in a Teststand container that would represent a linked list?
If it is possible how would you do it?
(3,551 Views)
There are several ways. You could link containers together with ActiveX references or with property objects you attach with the PropOption_NotOwning flag. However, the easiest way to have a resizable list in TestStand is to just use an array, either of container instances (easiest), ActiveX references to containers, or non-owning container properties.
You can insert items by calling the PropertyObject SetValByOffset methods with the PropOption_InsertElement option. You can delete items by calling PropertyObject.DeleteElements.
(3,551 Views)
Also, you could choose to use the tried-and-true array only solution for languages that don't have pointers (even though TestStand does have pointers, if you count ActiveX references or non-owning properties).
To create a linked list in an array, make an array of containers. Allocate new items by adding elements to the end of the array. Use a numeric nextIndex property in each container to indicate the location of the next item in the linked-list within the array.
(3,551 Views)
