NI TestStand
Linking seq files to teststand
It's at the address Al pointed to.  See attachment.
This is only for the sequence editor though.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 16
(2,797 Views)
BTW- because you have only the base deployment I'm going to assume you are using the UI.  In which case you'll need to point to that.  Which UI are you using?  Where is it located?
jigg
CTA, CLA
testeract.com
Message 12 of 16
(2,795 Views)
I am not sure what the UI is...
all I know is that when this system was working, I could click on the sequence file desktop icon and it would load the  sequence file
in teststand where I could  run the test...
Also, from your other post, I don't have the same files that you show so I am not sure which one to use...
Message 13 of 16
(2,784 Views)
This just means that you are running on the UI (User Interface).  Basically the machine you are on is what we call a deployment machine.  No sequence editor.
Do you have anything in the UserInterfaces folder?  I referenced it in a previous post.  C:\Program Files (x86)\National Instruments\TestStand 2014\UserInterfaces
Or another location could be here:
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\UserInterfaces
jigg
CTA, CLA
testeract.com
Message 14 of 16
(2,778 Views)
Thanks...
It looks like the same for both the program files folder and the User's folder which is shortcut to the following but this does not load the sequence file.:
Message 15 of 16
(2,767 Views)
Accepted by topic author robojeff
looks like the answer is to upgrade the license to teststand debug deployment ...
thanks for your help
Message 16 of 16
(2,758 Views)
