NI TestStand
List possible sequences
Jose Luis,
Estoy por echarle un ojo a tu vi pero me faltan los subvis, son los mismos del post pasado?? has cambiado el panel de conectores?
Saludos
Message 11 of 16
(1,925 Views)
Es posible abrir el VI del Jose Luis simplemente por referirlo a TestExec.llb (que esta en C:\Program Files\National Instruments\TestStand 3.5\OperatorInterfaces\ni\Simple\LabVIEW).  La unica diferencia principal es que Jose ha cambiado el nombre de Simple OI - Configure Event Callbacks.vi; puede simplemente referirlo a este VI cuando te pide.
Por favor en el futuro, escribe el mensaje en ingles para que todos puedan entender.
Translation: It's possible to open Jose's VI simply by referring to TestExec.llb (located in ...).  The only main difference es that Jose has changed the name of Simple OI - Configure Event Callbacks.vi; you can simply refer to this VI when it asks.
Andy McRorie
NI R&D
Message 12 of 16
(1,918 Views)
Hi << … ,
thanks for your interest. For what regards the subvi's, as Andy saies I just renamed only one.
Thank you
JL
Message 13 of 16
(1,881 Views)
Correction:For what regards the subvi's, as Andy says, I just renamed only one
Message 14 of 16
(1,879 Views)
Andrew,
I have a similar question.  I have a main seq that calls subseq's which also call subseqs.  Is it possible to create a menu that allows the user to select which subseq he/she wants to run ??  In the Main Seq I ask them if they would like to run in troubleshoot mode ( and therefore I set a global variable to 1) or end to end mode ( global is 0).  The purpose of the global is to turn the PS on/off at the end of each troubleshot seq.  If the user selects end to end test I turn the PS on and leave them on thru out the test.  Maybe I could use this global ( if 1 display popup because I now want to allow seq selection)  to cause a popup menu that allows the user to select which seq they would like to run??  Would I have to do the Menu selection in LV ??
The seq's and subseqs are all in the same file
Clint
Message 15 of 16
(1,604 Views)
Client,
It seems your question is being answered in this post. If not, let us know what additional features you are looking for besides the solution in that post.
Song Du
Systems Software
National Instruments R&D
Message 16 of 16
(1,574 Views)
