NI TestStand
Load Options for Edit Sub Step
Hi Ppl,
I have created a custom step type which has a edit sub step with LabVIEW adapter. When invoke the edit sub step for the first time, it takes a while to load the edit sub step and there is a noticebale delay for the first time. I want the edit sub step module to be loaded when TestStand is open or when the sequence file is open. I was not able to locate any location where we can specify the load and unload options of the edit sub step. Is there any way to do this ?
Sathish
(2,862 Views)
This is probably because of the launching of LabVIEW development system.
Have you tried setting the Load option for the SequenceFile to 'Preload when opening sequence file'
Regards
Ray Farmer
(2,859 Views)
