NI TestStand
Load UDL file at runtime
I'm using the result processing utility to write data to oracle at the end of testing. Is there a way to load the connection string from a udl file at runtime before processing the data? I'd like to share the same udl file for several test stations. The DB password changes every few months and it would make it easier to manage.
Curt
(1,680 Views)
I think should be possible.
Please explore the callbacks database options.
Try changing the connection string in the parameters.
Ravi
(1,571 Views)
