NI TestStand
Load a sequence file from a C# code module in the TestStand GUI.
I want to load a sequence file from a C# code module in the TestStand GUI. I do not use one of the user interfaces, but the default TestStand GUI. I have made an entry point in the Configure menu of TestStand, called “Show StartUp Screen”After clicking this option in the Configure menu, a C# method is called with as argument the sequence context.
Now a window will be displayed with possible sequences, after selecting one of them, I want to load this sequence in the default TestStand GUI, is this possible?
Best regards
(3,794 Views)
The API calls would be:
ApplicationMgr applicationMgr = sequenceContext.Engine.GetInternalOption(InternalOption_ApplicationManager);
applicationMgr.OpenSequenceFile(sequenceFilePath);
(3,788 Views)
Thanks a lot, it works great!
(3,781 Views)
