NI TestStand
Load more than one sequence file with c#
it runs :).
if (po.GetSubPropertyIndex("Result", 0, "Measurement") != -1)    // Ist ein Multiple Numeric Test
      Console.WriteLine("Name: " + po.Name);
      var array = po.GetValVariant("NumericArray", 0);
      for (Int32 i = 0; i < array.Length; i++)
         Console.WriteLine("Measurement: " + po.GetValNumber("Result.Measurement[" + i + "].Data", 0));
         Console.WriteLine("low.limit: " + po.GetValNumber("Result.Measurement[" + i + "].Limits.Low", 0));
         Console.WriteLine("high.limit: " + po.GetValNumber("Result.Measurement[" + i + "].Limits.High", 0));
In the next Step i had to change the active UUTs. If found the variable in
RunState.Caller.Parameters.ModelData.TestSockets[].Disabled
Is this the right place?
How i can get access to this variable before i run the testplan?
regards,
René
Message 21 of 25
(2,248 Views)
i test something.
else if ((int)e.uiMsg.Event == 10103) // RunState.Caller
	Console.WriteLine("\nUIMessageEvent: " + e.uiMsg.Event.ToString());
	Console.WriteLine("PreUUT: " + e.uiMsg.NumericData);
	SequenceContext seqcont = e.uiMsg.ActiveXData as SequenceContext;
	var par = seqcont.Parameters.GetValVariant("ModelData.TestSockets", 0);
	for (Int32 i = 0; i < par.Length; i++)
		Console.WriteLine("UUT disabled(" + i + "): " + seqcont.Parameters.GetValBoolean("ModelData.TestSockets[" + i + "].Disabled", 0));
		if (i == 1)
			seqcont.Parameters.SetValBoolean("ModelData.TestSockets[" + i + "].Disabled", 0, true);
If i run this code the test stops after this call.
UIMessageEvent: 10103
PreUUT: 3
'TestStandMultiDUT.vshost.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Dynamic\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Dynamic.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'TestStandMultiDUT.vshost.exe' (Managed (v4.0.30319)): Loaded 'Anonymously Hosted DynamicMethods Assembly'
UUT disabled(0): False
UUT disabled(1): False
UUT disabled(2): False
PreUUT: 3
UUT disabled(1): True
PreUUT: 3
The thread '<No Name>' (0x264) has exited with code 0 (0x0).
The thread 'vshost.RunParkingWindow' (0xe14) has exited with code 0 (0x0).
The thread '<No Name>' (0x4a4) has exited with code 0 (0x0).
The program '[2928] TestStandMultiDUT.vshost.exe: Managed (v4.0.30319)' has exited with code 0 (0x0)
If i commend out the red lines the test is running.
PreUUT: 3
PreUUT: 3
PreUUT: 3
UIMessageEvent: 10101
Testsocket: 0
seq.Name: MainSequence
Result: 5,123456789
LowLimit: 0,1234
HighLimit: 10,5678
Operator: GELE
Testsocket: 1
Result: 5,123456789
LowLimit: 0,1234
HighLimit: 10,5678
Operator: GELE
Testsocket: 2
Result: 5,123456789
LowLimit: 0,1234
HighLimit: 10,5678
Operator: GELE
I call the uimsg in the preuut callback
What is going wrong in ths state?
regards,
René
Message 22 of 25
(2,234 Views)
Hello Rene,
i get it to work. I sent the UImessage in the PreBatch Callback
On the UI side i write then the values in the local variables, but it should possible to write it direct to the
Parameters.ModelData.TestSockets[x].Disabled. This is the reason why i used an expression after the callback to set the values.
Parameters.ModelData.TestSockets[0].Disabled = Locals.Socket0,
Parameters.ModelData.TestSockets[1].Disabled = Locals.Socket1,
Parameters.ModelData.TestSockets[2].Disabled = Locals.Socket2
On UI side in LabVIEW it look like
I hope it helps
best regards
Alexander
Message 23 of 25
(2,216 Views)
with Callback in PreBatch it is running :). Now i had to implement it in the finale Application.
regards,
René
Message 24 of 25
(2,212 Views)
the part with collecting Result ist running :).
Now i am at the end of the Test. Each UUT is calling the EndExecution Event. And same other Callback also.
private void _appMgr_EndExecution(object sender, _ApplicationMgrEvents_EndExecutionEvent e)
      Console.WriteLine("EndExecution: " + e.exec.ResultStatus);
      Console.WriteLine("Sequence: " + e.exec.DisplayName);
How i can filter the Events? I only need the overall Results of the UUTs.
The overall Result is saved in  e.exec.ResultStatus.
My question: Where i find the Testsocketnumber? I need it to save the overall result into the uut results.
regards,
René
Message 25 of 25
(2,201 Views)
