NI TestStand
Loading StationGlobals from a custom file
I have two user that has different StationGlobals.ini.
They both has different variables.
Is it possible load stationglobals from different ini files.
Otherwise before they start the TestStand Seq Editor, they needs to copy/overwrite the Current StationGlobals.ini
(3,065 Views)
Hello tawame -
TestStand can only load one StationGlobals.ini file at a time unfortunately, and there is no functionality in the software to automatically merge the two files. While this has been suggested for future versions of TestStand for right now you will have to pick one of the two files and keep it in the TestStand/Cfg folder.
--Regards,
Elaine R.
http://www.ni.com/ask
(3,065 Views)
