NI TestStand
Loading default limits for every execution
Is there a way to set the "Unload after sequence executes" as a default? I couldnt find an option. I can unload the modules from the file menu, and also with a statement step, but I am wondering if I can simply set this as a default.
thx.
(2,631 Views)
Try Run Options ----> UnloadOptions and select respective Unload Option.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,600 Views)
yeah... I mean is there a way to set that behaviour the default instead of changing it from step to step? Basically I'd like this option to be active when I add a new pass/fail test or action etc to the sequence.
(2,597 Views)
Customize the test type and save, use the same when you are adding new step.
(2,595 Views)
My personal experience regarding flexibility, specifically regarding limits, is to NOT rely on the limits in the sequence steps. Use a property loader and make sure to load a "default configuration" during execution in each execution. You can use multiple property loader to modify specific values in case needed.
Norbert
Expert: Geometry
(2,577 Views)
