NI TestStand
Loading limits for tests in a loop
In the attached sequence I would like to load limits using a property browser.  Some of the tests are in a loop.  I would like to be able to specify different limits for each iteration through the loop.  Is there a way to specify this in the property loader?
Mike
(3,083 Views)
well, you must be able to do it as I did. but I think you need to change some execution preperty and put load dynamycally then you can specify the name of the file from which you want to read your limit by building his name with the expression browser
hopte it can help you
(3,074 Views)
