NI TestStand
Loading subpanels in a vi with TST
What is the best way to I load a vi with a subpanel  vi entry from TST and keep it open untill cleanup of the sequence file?  While the vi is kept open, I want to give a file path parameter in each step of my sequence to that vi, to load a new subpanel in it.
(4,134 Views)
Hello JoVMo,
So what you want to do is the following:
You want to have a main VI with a subpanel inside it.
The VI loaded in this subpanel should be changed depending on the step of the sequence you're currently in.
Is this what you are looking for?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,026 Views)
Yes Thierry,
I figured something out by passing the sequence context to the Top vi.
I'm looking for a decent way to pass measurements back from the subpanel to the sequence..?
(4,024 Views)
Hello JoVMo,
It seems to me like you're looking to create some kind of custom User Interface.
Can you take a look at the following Tutorial and tell me if this is what you're looking for?
PS: please correct me if my assumptions are in any way wrong.
Kind Regards,
(4,006 Views)
Thierry,
Could you be so kind to post the link to the tutorial  again. Because this link redirect me to a site that has nothin with ni.
I think I need a custom GUI. Because I require lots of interaction from an operator.
But I can't figure out what approach I must take.
(3,997 Views)
I found this example https://decibel.ni.com/content/docs/DOC-1756 .
Is there something made in LabView also?
(3,987 Views)
I guess there was something wrong with the link.
Here it is again:
http://zone.ni.com/devzone/cda/tut/p/id/7560
Kind Regards,
(3,968 Views)
