NI TestStand
Locals.StartMarker expression syntax
Locals.StartMarker = (RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit == 1) ? "Commercial Grade Specifications" : "Military Grade Specifications"
Locals.StartMarker = (RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit == 1) ? "Commercial Grade Specifications" : "Military Grade Specifications"  : "My Grade Specifications"
When I add a third button to specify a third set of vars in the .\TestStand 3.5\Examples\Loading Limits\LimitsFromTextFile, TestStand gives me a syntax error on the ":" between the second and third ( and new) test condition.
I have searched for a syntax guide for expressions. Is there an expression guide for these types of constructs?
(3,362 Views)
Ok,  I now see this is the ? : operator that only chooses between two expressions. and trying to add a third is not appropriate.
I'll look for another example on how to do this with more than two buttons to choose between.
(3,358 Views)
If you what to expand the expression try something like this
Locals.StartMarker = (RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit == 1) ? "Commercial Grade Specifications" : ((Locals.StartMarker = (RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit == 2) ? "Military Grade Specifications"  : "My Grade Specifications")
regards
Ray Farmer
Regards
Ray Farmer
(3,354 Views)
Linefeeds (try ctrl-enter) can make it easier to read. Also, there is no need to repeat the assignment:
A local variable can make it easier to read, especially if there are a lot of cases:
Locals.buttonHit = RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit,
(Locals.buttonHit == 1) ? "Commercial Grade Specifications" :
(Locals.buttonHit== 2) ? "Military Grade Specifications"  :
An lookup table array can also make it simpler:
Locals.StartMarker = Locals.MyMarkers[RunState.Sequence.Setup["Identify Limits to Use"].Result.ButtonHit]
(note, I didn't actually test these, so they might need some slight adjustment).
(3,344 Views)
Nice touch James
Regards
Ray Farmer
(3,329 Views)
