NI TestStand
Locals.a+ = Str(locals.b)+
Since i am not good in C++ language I am not bale to undertsand this condition....i.e
Locals.faultlist+ = Str(locals.faultcode)+"/n"
could you pls explian how this works.
(3,947 Views)
First, let us look at the right side of the equation.  Look like a fault code (number?) is being turned into a string and then an End of Line is added to the end of the string.  Now the += is a way to just add on to the value on the left.  So what you are really getting is a string containing what was already in the faultlist with a new number and End of Line appended to it.
(3,945 Views)
Thanks for your reply...
What does Str(Local.faultcode)+ indicates...i know you have mentione that this converts to string..pls let me know
(3,940 Views)
both faultcode and faultlist is declared as string
(3,938 Views)
the str(faultcode) converts the faultcode into a string.  The + appends strings.
(3,921 Views)
