NI TestStand
Location of station globals file
We must archive our TestStand code with ClearCase and the snapshot directory tree starts out with C:\__views. Everything fits nicely in this tree except the station globals I added which TS places under C:\Documents and Settings\All Users\Application Data\National Instruments\TestStand 4.2.1. Can they be moved? This is a bit awkward when moving things in and out of ClearCase.
jvh
(6,393 Views)
Accepted by topic author jvh75021
You can change the location of your cfg directory which contains the stationglobals using the preferences tab of the station options dialog. Changing this setting effectively sets a registry value with the cfg directory path to use underneath the Localmachine\National Instruments\TestStand\x.x registry key.
Hope this helps,
-Doug
(6,387 Views)
