NI TestStand
Locking a sequence file
Hi Pat,
Thanks for the info. I wasn't sure about the Saving of the File. The resetting of the protection, well that was an act of desperation when things weren't going as planned.
I'll give Scott's link ago.
Regards
Ray Farmer
Regards
Ray Farmer
Message 11 of 20
(2,271 Views)
Does anybody have the patch??? it was removed from NI's FTP
Message 12 of 20
(2,179 Views)
Hey N,
I believe you also emailed in regarding this patch.  If you haven't emailed in or you don't receive an email with the patch in the next day or so, post here again, and I'll see what I can do.
Message Edited by Patrick P. on 05-03-2007 01:14 PM
Pat P.
Software Engineer
Message 13 of 20
(2,149 Views)
Hi Patrick,
I got the patch from NI via email
Message 14 of 20
(2,135 Views)
Is this issue now resolved in TestStand 4.0?  If not, I guess I need the patch also.
Message 15 of 20
(2,014 Views)
This has been fixed in TestStand 4.0.
Allen P.
NI
Message 16 of 20
(2,008 Views)
We have a situation where, during several test steps (of type multinumeric), instead of embedding the upper and lower limits of a step in the SequenceFile itself, we read these from a configuration file (we make use of LabVIEW's Configuration Property Editor).  Anyway, in those cases, our VIs write back to TestStand to set the upper/lower limits (using the Sequence Context) so that TestStand can (at the end of the step) make the determination if the test passed/failed. However, if a sequence file is locked, will it allow you to write to it (temporarily, during the test).  If it does, then at the end, will it prompt the user if they want to save the file?
Message 17 of 20
(1,999 Views)
Locking the sequencefile doesn't stop you from modifying the runtime values. If it did, that would mean steps like the PropertyLoader wouldn't work.
Because you haven't changed the Count value, which signals that the sequence file has changed, you will not be prompted to save the file.
Regards
Ray Farmer
Regards
Ray Farmer
Message 18 of 20
(1,997 Views)
Are you referring to PropertyObjectFile.IncChangeCount ?
Message 19 of 20
(1,995 Views)
Yeah that would be one, you would use that one if you were working on the PropertyObjectFile. I think there is a similar one SequenceFile.IncChangeCount.
Regards
Ray Farmer
Regards
Ray Farmer
Message 20 of 20
(1,991 Views)
