NI TestStand
Log Result of Message Popup Button Hit?
Hello All,
  Trying to figure out how to turn a popup message into a test (i.e. the button that is hit determines if the test passes or fails).  I am able to retrieve the result and control data flow based on the result, but can't figure out how to include the result in the report.  I've been working on a "Custom Result" in the "Additional Results" section of the proerties tab, but can't seem to get the expression syntax right.  Please advise.  Thanks.
GSinMN
(6,518 Views)
Accepted by topic author GSinMN
You can use the Status expression to determine a pass/fail result. See attached sequence for an example.
Hope this works for you.
Mathijs
(6,513 Views)
Hello Again,
  Thought I should clarify something.  I can get the nuber of the button that was hit to show up in the report, but I want the text from the button that was hit to show up in the report.
GSinMN
(6,512 Views)
Thanks M.Haarman.  Exactly what I was looking for.  Glad it was easy.
GSinMN
(6,511 Views)
