NI TestStand
Log an Array with Additional Results into a SQL-Database
I tried to log an array of Numbers [0...999] into a SQL Server Database with the schema "Generic Recordset (NI)" and get the attached Error. If I don`t log the array, everything works fine.
Has anyone make the same experience or knows how to solve this problem?
If you google the error code, you will find something about a MySQL Database, but this doesn´t fit to the SQL Server Database.
(https://www.ni.com/docs/en-US/bundle/teststand/page/database-known-issues.html)
Thanks for your help.
Message 1 of 1
(2,087 Views)
